Hi
pulled the motor out of my 68 convert. 4"bore 3.25 stroke
block 3970010 2 bolt main
date code on rear flange has a 69 code.
010 020 under timing cover
The block has the following # stamped on the front pad . I would like to know what it was out of .
69y050192 VO613F2 (the F2 is clear as a bell)
Also which section has the parts that you try to get back to original owners? (tag team , bench racing ect) I have a 64 corvette block & a camaro Block
Thanks guys
Thanks guys
