All lights work except driver side brake light. Installed new flasher still no light. Any suggestions would be appreciated.
Bulb or ground
:yes: Check your ground with a meter
Does the turn signal work on that side? Be sure you have a brake light signal coming out of the T/S switch then trace you way back. It's possible the problem is the T/S switch.
Jeff
I had a similar problem last year. Turned out to be a corroded contact in the bulb socket. I replaced the taillight harness. Very simple to change out.
