I'm finishing up my 69 Camaro build and have run into a bit of a problem.
I can only turn the steering wheel about 3/4 of a turn either direction and the tire hits the front of the fender.
I've seen several posts that say NOT to use 2" drop spindles on first gen Camaros.
Not sure where to turn...
Any info and/or suggestions would be greatly appreciated
My car is currently equipped with the following
TRSD aka The Right Stuff Detailing front disk brakes with their 2'" drop spindles
Viking Coil Overs
OEM Control Arms - I plan to install a set of tubular upper and lower control arms. However, I'm told this will not resolve the turning problem.
Vision Torque 8.5" Wheel 4.5" BS -6mm OS
MT Street Comp Tires 245/40/18
I have moved around the alignment shims and gained a little more turnability but not enough.
Please let me know if you need more info or photos showing specific parts. Look forward to hearing from you soon.
Viking Coil Overs
