I have been looking at a/c for my 67 ss/rs. I will probably be buying a brand called "Vintage Air". Hot Rod shops use them because thy're built for higher HP motors. Check with a local shop. They should be able to look at your car and order all the parts. They can install or you can--from what I've heard, the install support is good. This may not be your style if you're set on looking for parts from older cars.
The Vintage Air set-up is the hot ticket for keeping cool (sorry, couldn't resist).
The kit runs about $1,000 and is very good. The ENTIRE assembly mounts underneath the dash. There is no A/C box on the firewall in the engine compartment.
I see two major disadvantages with the original style A/C:
1. The GM compressor is big and heavy. The Vintage Air system uses a modern aluminum rotary compressor.
2. Original compressor requires Freon (getting VERY expensive). Vintage Air systems use the new stuff.
Discussion Starter · #5 ·
<BLOCKQUOTE>quote:</font><HR>Originally posted by CarlC:
68-72 Novas are great donor cars and the stuff is usually cheap.
<HR></BLOCKQUOTE>
Thanks for the info - found an a/c system out of a 73 Camaro. The reason I'm using factory a/c is I'm running a unibelt pulley system from a 88 Z-28 that utilizes the small Harrison rotary compressor, also using wiring, evaporator from 88 Z-28. Just needed the housing for the evaporator and fan. Has fit pretty good so far, small amounts of fabrication, will let you know details when finished.
