can someone tell me how to wire the amp meter and temp gauge on my 69 camaro. The car was not originally equiped with console gauges. It had warning lights.
If you are planning to install the whole console guage cluster, get the wiring harness for the guage set up. This way you have all the correct connectors.
I installed console guages in my 69. I bought them used so the guage pod was already wired then I got the correct harness from classic. If your trouble goes beyond that you will probably need an assembly manual and or the wiring diagram.
Black 69 camaro
