The dash panels are the same with or without A/C. The padded dash pad on the non-A/C covers the center A/C vent.
That one will work, just fine. Be aware that if you change the entire panel, you will have to replace the VIN. Depending on what kind of car you are building, you might be better off getting a piece cut from a donor, and welded in.
