Can someone help, I installed new tank, used old sending unit, (worked fine before I change tanks)Now guage reads at 3 o"clock. I have check fuse, all connections including ground. Can't seem to make it go back to normal position. Camaro Muscle
Gauge pinned high indicates open circuit. Make sure you have the ground wire from the sender reinstalled on the trunk stiffener infront of the gas tank, above the muffler.
Thanks MArk, I took the sending unit out, and the groung was barely arrached. I redrilled the ground and tha fix it.
