1 - 13 of 13 Posts
Hi,
Looking for some help...please
My 69 Camaro has become a real "bear" to get started after it sits for two weeks? This had not really been the case in the past? Trying to think if I changed anything that could be root cause to a change? The gas filter is new but same type I always use, so no change there.
The starter is new. The carb is 2 plus years old and was a brand new Edelbrock that I bought, Thunder series 4 bbl.
Here is the symptom-car cranks and cranks- repeat cranking 6 and 7 times before it seems gas is getting to carb to start engine. When gas seems to arrive car starts right up. What do you think is happening? Worth noting, the car is running great once started. Strong and smoothe, no hesitation or misfiring at all. Plugs were replaced 1000 miles ago and car was starting right up back then. Old plugs looked real clean.
Could the starter not be cranking hard enough to push fuel pump hard enough to get gas up quickly to carb? Could there be problem with carb? could fuel pump (edelbrock 1721 I think) be on the way out? Although car runs great when driving...
Could the float bowl be empty after sitting for two weeks? Check to see if there is a accelerator pump shot before you crank it the first time.
Jeff
I do pump the pedal to the floor once before cranking...what should I be looking for at the carb after that one good pedal to the metal?
thanks
Joe
If you have the stock points ignition, make sure the wire from the starter solenoid (believe it's the small terminal furthest away from the block) is still connected up to the + terminal on the coil to give 12 volts when cranking. I had one come off years ago, what a pain to start.
Jody
Before you pump it the first time remove the air cleaner and look down it while you pump the gas . You should see a pump shot if there is gas in the bowl. You want to see a good strong pump shot not just a mist or sputter. If the bowl is empty you need to determine if it leaks out or evaporates.
Jeff
After you park the car and it's hot, especially with an edelbrock (from what I have noticed) the fuel evaporates from the heat, if you are running a mechanical fuel pump, it has to refill the bowls, this takes a few revolutions, if you had an electric fuel pump, it would probably fire right up.
No big deal, a lot of our cars do this.
After sitting a while mine takes a min or two and a good 5-8 pumps, a lot of people hold the pedal to the floor after a few pumps while cranking.
Take the top of the carb off and re-set the fuel floats, mine were way too high, and would stall under a low speed sharp turn because of this.
The owners manual will tell you how to do this, it is easy.
With today's fuels, fuel in the float bowl will evaporate on almost any carbureted car if it sits for 2-3 weeks; if any of mine sit that long (and at the end of winter garage storage), I fill the float bowl first through the bowl vent tube. They start right up without cranking until the pump can fill the float bowl, which is hard on the battery and starter. An infant formula syringe or restaurant plastic ketchup dispenser bottle works great. :thumbsup:
Discussion Starter #9
I am going to try a different type fuel filter...my friend said my filter may be to large and causing to much fuel to have to fill the filter and then move through the line and onto the carb? We will see what that yields...
thanks
Joe
I am betting it is the Edlebrock. All of them I have tried do the same thing. None of the Holleys do it so this rules out the fuel. I no longer have anything with Quadrajet even though they are good. Try a phenolic spacer, it could improve. I have just learned to deal with mine, only one vehicle left with Edlebrock, since there isn't clearance enough to put much of a spacer in.
like said before by johnz ..all my cars with carbs and that set..that long takes some spinning to start...of course that does help get oil pressure up .then 1st pump squirt of gas they fire up fine...
1 - 13 of 13 Posts
