just changed to aluminum heads temp sensor to big it's 1/2'' need it to be 3/8'' iam running stock gauges, looking for a sensor 3/8'' pipe sensor that will work with stock gauge!! :hurray:
Re: 69 camaro w- guges temperatur sender
Is there not a place in the intake for it?
I went with this setup on one of my engines so I could use the original sender. Look on the thermostat housing. Worked good.
