1 - 8 of 8 Posts
We're finally getting ready to work on the interior of our Camaro, and most of the new parts are in. Quick question... I was looking at the new standard door panels, and I'm not sure how the clips attach to them. Any help would be greatly appreciated.
Thanks,
Chet
On the panel back there should be slots cut out on the front and rear edge of the panel. The clips slid into these.
Discussion Starter · #3 ·
Thanks Clash, I'll look at them closer when I get home today. One other question... What is the best way to line up/drill holes in the panel for the four bottom screws? The car doesn't have old panels to compare, and I'm pretty sure I didn't see any marks or knockouts on the new panel.
Thanks again,
Chet
Chet...Try making a template out of paper or cardboard and transfer the marks to the new panels.I would'nt use a drill,you might slip.Try using a awl or a sharp punch.
Hope this helps.
Bob
Look on the back of the panel. Some of the new ones don't have the plugs of cardboard removed for the clips but there should be perforations where they are. You have to use a small screwdriver and box cutter to remove them. Be careful not to cut all the way through. The plugs only come out of the first layer of cardboard. A couple of them may be under the vinyl on the ends. You have to pry up the edge just enough to find them. Good Luck.
69 SS, 350, 4 Speed
75 400, 4 Speed
93 Z28, 6 Speed
I had the same problem with the clips on the door panels. I ended up just using double sided foam tape. Works pretty good so far. As for the holes in the bottom, I used a punch. I wish i thought of using a template...oh well.
69 Camaro RS (SS Clone) 350 Daytona Yellow
1 - 8 of 8 Posts
