Hey,
Thankyou very much for the data......I'm wanting to keep motor all OEM.
Thanks again
Greg
1969 RS Z28
Hugger Orange
Greg what Eric is saying is you can order it from GM, but GM will send you the cam made by Crane. GM no longer makes this grind, but uses Crane as their supplier for it. There is no OEM 302 cam any longer unless you find an NOS one, which do appear occasionally for sale. So you might as well just buy it from a supplier like Jeg's as Eric suggests.
Clevite also offers many of the original GM grinds as well, but are a little more difficult to find unless you know the duration, lift and valve event timing info already for the cam you are looking for. I used a Clevite replacement for the last 302 1st design off-road 140 solid cam.
Dave
Banned
This should be Clevite's 20-30 cam....
PN 229-1612;
294/254, .110/114, .485" lift and need's .030" lash on both sides; and this one
Elgin's;
PN E-901-P; 314/254, 114/110, .485”, Lash, .030” on both sides too.
pdq67
All good options........I used the Crane Blueprint cam and recommended springs, ordered from Summit. It worked out great. Just make sure you use the "JOHNZ" method of valve adjustments. Mine are "solid sounding" if you listen close enough, but not at all noisy.
