ok, I have a problem with my 1969 Camaro. It will not turn over, and the headlights will not turn on, though the dash lights, and dome light do come on. What should I check, and how do I check it/fix it? I know almost nothing about it, so I'll need in depth guidance. Thanks.
Headlight problem usually points to the passenger fender ground not hooked up or having a bad connection. Make sure you have a good solid connection from the ground on the battery to the hookup on the passenger fender.
