I have a 69 camaro SS. I have not put a full tank of gas through it as yet. The gas gauge seems to go down fast and I ran out of gas at about 1/8 full. I put in 6 gallons which brought the gauge up to the right side of full , in other words way past full (needle at 3'clock). I did not fill it because I may have to drop the tank. Would this be a faulty gauge or a grounding problem? Any insite would be appreciated.
Does the instrument cluster have an actual ground strap/wire or just grounded through the dash?
Thanks for the input guys. It was a faulty ground at the back. I used the notes to check the sender etc. Will file them away for future use. Case closed!
