I'm working on an original 69 pace car and having a problem with the R/S headlight doors.
Everything works fine until you shut the car off and about 5 seconds later the Rt door opens half way and the LF door opens about an inch or so.
Replaced check valve
checked all the lines ( yes they are old but seem to hold vac.)
Anybody have any ideas before I throw lines in this car
# 303 489 1872
Thanks Steve
What I don't get is they open AFTER the engine is off.(no more vacuum except the reserve tank) Strange. Maybe it's valving from the tank. Try, with a helper, having them shut off the engine and you pull the hose from the tank instantly. See if they open then.
