I did a search and only came up with how to remove the back seat bottom. I already got that out. Now how do I remove the back? I can see that on the bottom there are two rods that slide into a bracket. So I know that the seat has to go up to remove. Feels like there are bolts holding the top of the seat. I looked from the trunk, but couldn't find anything.
Somebody set me straight.
There a a couple of bolts under the lower edge that have to be removed. I think there are also a couple of tabs in the same area that get bent over. In any case, just check along the lower edge for the fasteners/tabs and remove them, and then lift the seat back upward. It should pop right out.
Sounds like you are on the right track. The seat back does have to come up off of the brackets/hooks. Try pulling out a little on the bottom and pushing up at the same time. It's most likely just being stubborn since it's been there so long.
P.S. The brackets/hooks I am talking about are towards the top of the seat and you can not see them.
Robert
'69 getting better every day... (every pay day)
[This message has been edited by rojo (edited 04-08-2001).]
