1 - 20 of 318 Posts
Shawn Lemans Blue 1969 Camaro LS3, TKO 600
Well after four months into this project I thought it was time to start a build project post.
The car is a 69 X44 that i bought as a project car that someone had ran out of funds to finish.
The build plans are 5.3 swap, TKO 600, 8.5" 10 bolt, right stuff disc brakes, Holley LS swap kit with hooker headers, Hotchkis TVS stage 1, SC&C Stage 2 plus.
More pictures to follow once I figure out how to do it more efficiently than one photo at a time.
Discussion Starter · #7 ·
Subframe is out and heading to the media blaster.
Discussion Starter · #8 ·
Sub frame back from media blaster. Spraying the inside of the frame with a rust protector.
Cool project, keep posting pics. The easiest way to post pics is to get a free photobucket account, post the pics there and copy/paste the image links here.
If you want one of the pics to show up like you posted above:
http://www.camaros.net/forums/picture.php?albumid=3513&pictureid=2250
You need to use the image tag. It would look like this below, except you remove the space before the "img" and "/img". If I typed it without the spaces, the image would show up instead of the words:
[ img]http://www.camaros.net/forums/picture.php?albumid=3513&pictureid=22505[ /img]
Here are your pics with the correct "img" tags:
Discussion Starter · #15 ·
Thanks Brent that is very helpful. I will give it a try.
Discussion Starter · #18 ·
Very cool project Shawn. The driver looks ready to go!..;):thumbsup:
Keep the pics rolling in!..:beers:
Thanks Joanthon. He certainly is.
1 - 20 of 318 Posts
