141 - 160 of 305 Posts
Shawn Lemans Blue 1969 Camaro LS3, TKO 600
Discussion Starter · #141 ·
No pictures, but I have the fuel tank and fuel lines all installed.
Had to send the headers out to get re-coated. They had never been used or exposed to the elements, yet they developed rust. I was just going to let it go, but I couldn’t take it. I talked to Holley and basically they ignored me. They didn’t even have the courtesy to respond to an email.
Next will be the Vintage Air and Cold Air intake install while I wait on the headers.
Discussion Starter · #142 ·
The Specter muscle car CAI came yesterday. Started reading the instructions and find out you need a welder for the MAF pad. Specter website says only tools needed are wrench, extension, flat blade screwdriver, alllen wrench and only 90 minutes to install, lol. Should have read the instructions online.
Discussion Starter · #143 ·
Does anyone know if the Specter heat shield is supposed to be bent like this?
264020
Discussion Starter · #144 ·
Got the serpentine belt installed. Used Continental #4061010.
Lower radiator hose, Dayco 71244, will work after some trimming. The upper radiator hose, Dayco 70786, works fine as far as the shape goes, but ID is 1.5” and I just realized I need 1.25”. Should have gotten the calipers out before going to the auto parts store.
Discussion Starter · #145 ·
Wasn’t able to work on the car for the last week. I woke up at 0300 last Saturday with a pretty bad pain in my knee. It was swollen and the redness was all over my knee and down my leg. Put ice on it and limped around on it until my wife convinced me to go to the doctor on Wednesday. The doctor drained over 4 cc’s or fluid off my knee and gave me a cortisone shot. I am much better now. Not a 100 percent but able to work on the car again.
I was able to successfully install the Vintage Air evaporator. Just need to remove one more time to drill for the drain hose.
Discussion Starter · #147 ·
Looks good, kind of similar to what I did. Did you do the crimps yourself?
Thanks Tim. Your pictures of your install were my guide and helped out tremendously. Yes, I did the crimping. Hope they don’t leak.
Discussion Starter · #149 ·
So the fluid in my knee had staph infection in it that got in my blood stream so I have been unable to work on the car for the last couple weeks. Lesson learned is try and clean your cuts.
Anyway I was able to get out in the garage again this weekend. Got the headers back from a local powder coater and they look so much better than Holley’s coating. If I had to do it again I would just buy painted headers and send them out for coating.
Worked on finishing up the Vintage Air install. Need to clean the wiring Up and I am going to replace the metal clamps with the Gates Power Grips.
Discussion Starter · #151 ·
The headers look great. I'll be curious to see how they hold up over time. Not really clear on the durability of powder coating in a high heat environment but time will tell.
Sorry for the confusion Tim. The headers are not powdered coated they are thermal coated like Jet Hot.
Specter intake installed. Could not get the heat shield to fit, oh well should be fine without it.
I don't see your MAF located on the intake?
Discussion Starter · #155 ·
Installed Dakota Digital GPS, ODB, Cruise control, Vintage Air controller and fan controller. Used industrial Velcro to mount all the controllers. All this wiring has been kicking my butt.
Tim - The Northwest 1969 Camaro
That's a wiring party you have going there under the dash! You're making good progress, I think you are going to beat me to the finish line. I had to send my intake back to Frank to move the MAF boss as it interfered with my power steering reservoir. I am guessing those are Detroit Speed fender braces? Curious if you are happy with them?
Discussion Starter · #157 ·
Thanks Tim. I still need to clean up and organize the wiring. Yes those are Detroit Speed fender braces. I like them but they have limited me in CAI selection. I could not get Roto Fab to work.
Discussion Starter · #158 ·
Got the instrument carrier and the steering column. Hopefully I will be starting it up soon.
265156
Discussion Starter · #159 ·
Had another little setback. The staph infection came back and I haven’t been able to work on the car much. The doc put me on some stronger antibiotics and I am on the mend.
Anyway I had to drop the gas tank to fix a small leak at the fitting going into the tank. I was happy it was not any of the hoses I made up.
My son is coming over today to help re-install the tank. Today is first start up day, wish me luck.
Good Luck Shawn! Take some videos. First start happens only once. I'm excited for you.
Brett.....
