What is the proper location for the 69 RS back-up light wire grommet coming into the trunk. I have seen it on either side of the bumper bolts. Is there a factory indentation or something that would show if a wire is located properly?
if you look at the bumper brace that welds to the tailpanel and the trunk floor that the bumper bolts go through you will see a half circle cut into the brace where it sits on the floor. that is where the pigtail wire goes (1/2" hole). you'll have to look at your taillight harness to make sure you pop the hole on the correct side of the brace as they are interchangeable left to right and have the cuttouts on both sides.
:) :beers:
Thanks for your replies, and picture. I did try a search prior to posting but came up empty - so I consulted the specialists..................:) Thanks again.
