1 - 2 of 2 Posts
Outside Lamp is Tail Light/Stop/Turn
Inside Lamp is Tail Light
What is Center Lamp?
Mine is converted to RS Lens and the Center was Back Up?
What should it be NOW?
Nothing, center is a blank on RS. On RS, both inside and outside are stop/turn/park. The backup light on RS is moved below the bumper. If someone just changed the tailight lens, without changing the harness, the taillight housings and cutting the valence to install the backup lights, I suggest you put the standard lens back in. or doing the work to correct it properly.
1 - 2 of 2 Posts
