:hurray:I am going over my wiring on a 69 I just bought and my left signal light works as should front/rear but when I turn on my right signal both sides blink like I have my hazard flasher on?????????? I really could use some help if anyone has any information.....thanks Mark
Check/clean ground connection on right side.
Both bulbs per side are the same number.
Jiggle the turn signal lever a little.
follow the wires from the back of the bulb socket and track the grounds that way. If you dont have the AIM Assembly Instruction Manual, get one. they show the wiring and the rest of what you need when you own one of these cars :) brown is your 12v wire and black is ground.
WOW..........thanks for the help and diagram.....luv this site for amateurs like myself........thank goodness there are experts on here for help.......be cool man....
