1 - 20 of 27 Posts
With the screwing we got by Photobucket, I'm moving on and not looking back. I have a ton of pics from the resto of my 69 that I think helped a few guys on the way, so I wanted to put them back up for anyone else that might like to reference them. If you have any questions or need a specific pic, let me know and I'll see what I can do.
Here's how it all began... We've had the car since ~1982. The first pic is from the mid 80s after an 80s new 1/4s job. Pop rivets and lap welded 80% panels. What a mess. They've since been replaced. The next pics really start around 2008 when I pulled it in my garage and started dismantling it for a new floor pan etc. After many delays that saw her put in the back of the garage under cover for long periods, I finally started it in June 2016 and drove it all summer.
The born with 396 was put in the corner and replaced with this 72 Suburban 454. I pulled and sold it almost immediately with early plans to run the original 396.
Discussion Starter #2
In the 80s it was converted to an automatic. That's why the auto shifter hole can be seen in this pic.
Yes. This is a blue 55 gal. drum barrel... Ugh lol
Enough of the sins for now.
After the move to Michigan, I kicked it into high gear with plans for a solid, day two driver.
New floor and 1/4s. The rockers were replaced with original 69 perfect rockers. Same with the seat pedestals.
Discussion Starter #4 (Edited)
I didn't like the way the new floor pan didn't have the seat belt supports like the factory did, so I moved them from my old floor pan to the new one.
With a little help from my oldest son...
Subframe R&R
I left all the factory slag/spatter welds...
Posi Rear End. BS 3.31
Discussion Starter #8
Discussion Starter #9
Discussion Starter #10
Discussion Starter #11
Discussion Starter #12
Discussion Starter #13
Discussion Starter #14
Discussion Starter #15
Discussion Starter #16 (Edited)
Discussion Starter #17
Discussion Starter #18
Discussion Starter #19
Discussion Starter #20
1 - 20 of 27 Posts
