1 - 2 of 2 Posts
Was wondering if anyone has redone their 69 front bucket seats using the foam with wire even if your seats didn't have the foam with wire (from the factory). I'm getting ready to do mine and am looking at the PUI stuff and they show foam buns with & without wire. Will the wire ones work with standard seats?
Thanks for your replies!
My seats had all the slots for the separate back springs, although it had the internal springs in the foam from the factory. I'm almost positive you can go to the one piece back foam.
Just my opinion, but you might consider installing new seat springs and buns while you are at it. Most springs are broken, and those that aren't, probably will be. If your luck is like mine, the spring will break the day after you install the new seat covers.
1 - 2 of 2 Posts
