1 - 11 of 11 Posts
I just got my Z/28 back from having it restored and I am having trouble with the amp and temp gauges. The lights are not working on these but the bulbs are good. Also when I turn on the headlights, the temp gauge swings full right and stays there until I turn the lights off. I have tried to remove the cluster to check the wiring but I am haveing trouble and I don't want to break anything. Any help would be appreciated. Thank you.
I would guess a bad ground is causing your problems. The temp gage should have 12V in and grounds at the sensor in the head.
I agree,
there should be a ground under the console.is it connected?
Gary
Thank you for the reply. Can you offer any info on removing the cluster so I can check the wiring? I noticed that you have a Lemans Blue / Ivory Camaro, I looked at the picture, good looking car. This Z/28 is a Lemans Blue / Ivory Interior and White Vinyl Top.
Thank you
Chris
Remove the shift plate (4 screws)
Remove the lense panel covering the gauges (2 screws)
Reach under the console thru the shifter area, there are 2 screws,5/16 heads (I think). Remove them. The picture shows the screws
After removing the rear screws, slide the gauges rearward, lifting at the back.
Maybe this will help.
Discussion Starter #8
Thank you. I will try to get it fixed this weekend. I have been working in this car for two years and have a few little things to complete. I can't wait to drive it to a few shows and have some fun with it.
Chris
Discussion Starter #10
Gary,
The cluster came out fine and I found that the ground wire from the tunnel bracket runs to a bottom post under the fuel gauge. I connected a temperary wire to the tunnel bracket and then to the housing of the temp gauge and the amp meter and the console lights to the rear gauges worked fine. Should I run a permanent wire to the housing or to one of the four terminals on the temp gauge? Thank you Chris
Discussion Starter #11
Thank you, it worked fine. Chris
1 - 11 of 11 Posts
