Looking for details on a 69 Pace Z11 396/4spd I purchased. Really sweet driver and appears to be mostly original. Has CE engine and I'm trying to find out if it is the correct CE for the car. #TO61OGLB2885 is the engine #. The body plate #'s are ST69 12467 NOR 288004BDY, TR720 50AR RDT? 03D Z11. Trans/Rearend #124679N621940. Any record of how many Z11 396 4spd's made? By the way, the car does not have hideaway lights on front. Any chance there was a 69' Z11 produced without them or was this likely a replacement by someone not knowing better? I don't know if the miles are correct but it has 52K and is a very tight and great driver. Thanks for any details you can provide.
Hate to say it but it should have the RS hide away lights if its a Z11 Pace car. Try posting this in the Tag Team section, there are plenty of Pace car owners there that will help you with any questions about the car.
Jeff 67/68 & 69 RS's
Also - double check the tag info - 50AR RDT - doesn't seem like correct #'s -
if they are hard to read - try placing a piece of tin foil over the tag and rubbing it down - will make easier to read - or you can pull foil off and get it out in the open, where you can read it easier.
Steve
My Cars
