I AM ASSEMBLING MY 69 DZ 302 AND HAVE A FEW QUESTIONS I CAN'T
FIND THE ANSWERS TO.WHAT IS THE TORQUE ON THE WINDAGE TRAY NUTS? DOES THE RAILS ON THE SIDES OF THE OIL PAN GO BESIDE THE WINDAGE TRAY OR SET ON THE TRAY.
THANKS,DAVE
IIRC they are 3/8 threads so about 35 ft-lb should be fine- may add threadlocker too
I've a 68 010 4 Bolt Block with 67 Grumpy Spec'd 281 Heads. I used the OEM Vette Windage-Tray and 4 Qt Pan that Bolts to the outer Studs of the 4 Bolt Main Bolt - which basically was the man reason I choose the 4 Bolt and probably the same Tray & Pan used for the DZ 302. I run the large Journal Forged 3.25" Stoke 68 327 Crank and forged TRW-L2166NF30 pistons to give me an 11:1 Static Compression. I choose the Sigerson F-296-1 SFT Cam which gives me an 8.2:1 Dynamic Compression - She's a 8000+rpm motor and has been shelved until I tire of my 625Hp 7000rpm LS4 - One of these days, I want to get back into a LT1 SBC with a M21 & 3.55 Gears.
