As you can see by the PIC below, rather then using the Backup lens I’m running a DUAL RED lens cluster. I extended the wiring harness from the outer pod to the middle pod so that I have 4 tail lights rather then 2 – similar to a Vette or Ferrari. The only problem is that the Turn Signals flash TOO FAST – probably because of added resistance to the circuit with the extra bulb.
How could I slow the Flash Rate down? Change out a resister in the Flasher (which seems like a lot of trouble), find bulbs with less resistance (which I’ve tried but can’t find) or would a flasher from a Vette work? Any Ideas!
