the picture is right . if you had an external cooler on there but if you dont follow it the same way. im also a transmission rebuiler you want the hot fluid going to top of radiator just like your upper water hose goes to top of radiator. also if you hooked it up backwards the torque converter may drain back also causing a delay in gear when sitting a couple of days.
