Guys, just got a 700R4 to drop in my '73 RS and after reading prior posts here and on NastyZ28.com I thought that the crossmember mounting was going to be easy. It doesn't appear so. I've got a TH350 c/m.
All of the other info I have read said that you either have to relocate the c/m back and mount the front c/m holes in the rear frame holes or turn the c/m around backwards.
I can't see how either method will work. Moving the c/m back will get you about 3" and turning it around will get you 12". It looks like the 700R4 mounting is about 7.5" farther back than the TH350. If I cut the mounting bracket off and rewelded it on the other side it looks like it would be close. I hate to do this but may not have a choice unless I want to spend big $ and get the BTO one.
Any other ideas? What did you have to do?
Thanks - James
Thanks - James
