i have a 86 camaro z28 with a 305 tpi and the 700r4. my problem is that when i shift into drive my car jumps and shakes around and when im racing it shitfs really hard. the guy i bought the car from said it had a broken trans brace but i had it up on a lift and coludnt find one that was broken. it may have just been that there was one that i couldnt find.
hey im not no expert but i think it could be your motor mounts or your transmission mounts it could also be the vaccum line that hooks into the tranny not sure though about that year of camaro, but if there is no hose hangin down that probably aint it .good luck
3rd gens (and 4th) like to break the transmission mount. The stock ones are just weak. I used the urathane ones and it never broke again. The mount will give you the problems you are describing.
Mark
Mark
1992 Firebird 355/Six Speed
1991 RS 350 / 700-R4
Hey I have the same car and had the same problem after installing a B&M shift kit. It was the transmision mount at the tail of the tranny . It didn't look broke until I took it off.
[This message has been edited by thumper7999 (edited 11-06-2000).]
