I have recently installed a 700R4 in my 68 Camaro. I used a TH350 crossmember and simply slid it backwards. I used the back holes in the frame with the front hole in the crossmember. I then drilled new back holes.
I haven't gotten my driveshaft shorten yet, but does anyone see any problem with my solution? Is there a problem with the tailshaft being too high and causing pinion angle problems? Anything???
Thanks for any help.
Robb
Your tailshaft will be high and pinion angle will be off.Good chance of u-joint problems down the road.I'd be thinking about doing some mods on the stock one or buy one from these guys at www.700r4.com for 149.00$ The one I bought works perfect.
I used my original 350 crossmember. I've had it in the car for about 3 years now. I drive the car hard, runs 12's and I've never heard a driveline sound.
68 468 700R4, and here it is;
mutert23
MarkM
Did you simply slide the crossmember back as I described? Did you do anything to try and lower the trans?
Robb
Love your car!!!
Yup, I just slid it back, drilled new holes and bolted it in. I also timmed the front lip of the c/m a little to clear the tranny pan.
Thanks Mark
I think I'll get a new stock replacement trans mount. The poly one that came with my kit is a little thicker that the old rubber one. Anyone else noticed this? This would raise it even further!
Thanks again
Robb
I did just as MarkM described on my 700R4 install, and I used a poly mount. I did this about 5 years ago, and haven't had any problems.
Well,I checked with the "Driveshaft Gods" Inland Driveline Service....no matter what crossmember you use they told me I should have 3 to 4 deg. down angle on the transmission in realationship to the driveshaft.If anyone has any driveshaft questions they can got to www.iedls.com for information.
