1 - 2 of 2 Posts
No. a second generation Camaro rear end is 1 inch wider than a first gen car. I have used them in First gens before but you will have to move the spring pads in. Also the rear end will be a 1/2 wider on each side, but if you are using 7 inch rallys its not a problem.
i hope this helps,
Nick
69 Z/28 X77 D80 81000 original miles,DZ 302, M-21, BU 373 Rear End, ZL-2 Ducted Hood, Daytona Yellow, Black Deluxe, Tilt, Factory AM/FM, Console Gauges.
1 - 2 of 2 Posts
