My cruise and my washer do not work at all.My wipers work properly on low and high settings But in off position it acts like its on high delay and when I put it on delay the wipers just stop wherever there at on the wind shield at the time and do nothing until I switch to one of the other settings.HELP!!
Bob Phillips
Sounds like a ground wire problem, both units could share a common ground wire. look around for a wire that is disconnected around the fire wall area of the wiper motor
One other thing, did you pull the washer pump off the wiper motor? You have to use a pin to line the pump cam up with the the motor carnk, if you didn't then you will find that the pump cam is busted.
