I have an 86 camaro that came with a 2.8L v6. About a year and a half ago the engine blew. I want to put a 350 carburated model in it but im not sure what kind of upgrades the car would need. Will the 350 bolt to the existing tranny? Will i need to replace the current rear end? And will there be a need to change out the radiator? Any input would be much appreciated.
Your tranny will not work. It may bolt up, but won`t last long. The rearend doesn`t have to be changed, but the factory rearend is weak. The radiator will have to be upgraded as well. You`ll need new motor mounts, but can`t really think of anything else that would need to be changed to make work.
Tranny wont work and the rear end will explode if making good power. You will need better cooling fans and radiator... Jeremy is right!
welcome to team camaro!!
as the aboves stated
