1 - 8 of 8 Posts
There are some that fit but you won't find one{58 to 60 ford}. Big gear head is the man to talk to it is his business.
I haven't actualy tried it, but i"ve been told that early Mustang and Fairlane rear ends will bolt in with little effort. I build 9" Fords that bolt in Camaros and use the stock Camaro brakes and spring mounts.
'69 RS/SS396 pro street
427/4spd/9"
I got a 9" with 3.25 gears and a posi from a friend that does '66 Fairlanes. I had the 28 spline axles and drums drilled for a Chevy bolt pattern by Moser. I cut off the old mounts and welded on new ones. The width is within 1/4" of the original 8.2".
thanks guys. I think i know where a 67 or 68 fairlane is sitting but it will probly be like everything else, will set around and rot down. Owner probly wont sell.
1 - 8 of 8 Posts
