Intake-valve covers??? Cant see all that good??
Many of us have crawled around underneith looking for an elusive oil leak only to find a little dribble from a valve cover has found it's way to a dripping-off point down below (as Bill stated). So don't overlook that - it can boggle the mind.
Otherwise I'd suspect your oil pan / timing cover may be leaking. Perhaps the fuel pump push rod bolt hole is open. Timing cover could be it, or perhaps oil has found it's way between the crank snout and the damper.
