i drove z yesterday, car had been running fine a few days earlier. but not yesterday it died 3 times on me.every time i had to stop at a light or for traffic car would stall. just like it was turn off. let it set for 2minutes it would start back and drive and run for several miles. any ideas or help would be greatly appricated. thanks re jesse
The Torque convertor lock-up switch on the brake pedal or the solenoid inside the trans may be bad - causing the convertor to stay "Locked" when you go to stop...
Try removing the fuse (if it has one) for the convertor or disconnecting the electrical connector on the trans and then test driving it - if it doesn't stall you'll know it's that system and can troubleshoot from there :thumbsup:
Excellent advice John. That a likely cause and very simple troubleshooting tip.
