1 - 1 of 1 Posts
i checked fuel pressure with key on car not running...it was only at 30 psi. the pump sounded intermitent. the car will start fine then die after a second or two. i tested the circuit for the fuel pump relay and it only holds 12v for a few seconds then drops to 2v....then from there decreases down 0.5v.
any thoughts?
...relay tested good.
1 - 1 of 1 Posts
