My sons 94 camaro with the 350 in it has developed a problem, it is lagging on acceleration, will not go over 80, and when you are heavy on the throttle it sounds like there a belt loose at the rear of the engine( i Know there is no belts there, it what it sounds like)
I have poked around alittle looking for loose hoses and a plugged intake but I don't see anything that looks like a problem.
I am a diesel man myself so any help in where to start looking next would be much appreciated
oxygen sensors will cause a loss of power and the engine to run lean. have they ever been changed? have you had the vehicle scanned by an obd 1 tester to see if their is an issue the pcm recognized?
The earlt LT1'S did suck intake gaskets and cause lean, conditions, and/or smoke if they
went to the inside. and there are a lot of other vacuum leak areas.
Thanks for the replys, I did not have the time to deal with it so I had the kid take it to the garage in town, The cat was plugged up.
