my 94 has coolant smell and light smoke in the exhaust, going out now to do compression. What are the options here, a bad gasket or a cracked head?
When I go to start it, it must putter a second to clean out the cylinder and then runs normal. Haven't started it since I noticed this. Has all original parts, just the common parts of wear have been changed. I see no leaks except one of the bolts for the water pump dribbles some.
I'm open to anything at this point.
Be sure to examine the plugs as you pull them. The porcelain will be whiter on the wet cylinder.
As pointed out in a previous post, check in search with..."water from exhaust" where there's previous discussions in detail on this topic.
capt
94 what? Z28? 6 cyl?
