I have a 95 Camaro V6, bought it and discovered that it had a jumper wire between 30 and 87. It was removed while I had a few repairs done. I reconnected it and it started up fine, but after putting the jumper in the other two slots and trying to start again it will not crank or start. The only dummy light that is lit is the check gauges one. No fuses blown in both fuse locations. Need help ASAP! Thank you!
