Hi Guys I'm new to this forum. Been watching in the back ground for awhile. I am having a problem with my 95 it has a 3.4 litre 5 speed. When I turn the key nothing happens for a while if I turned the key hard it would start now nothing. Yhis is what I have done so far but with no results. I changed the clutch sensor. The ignition switch down on the column battery and starter, I don't think there is much more to change but it still wont start. Any help will be greatly appreciated. Thanks Ed
Ed,
Is the security light flashing on the dash? If it is, your ignition switch may be bad. There is a chip in the key that must make contact with the ignition switch. That's what happened to me and of course on a Friday at work.
Jeff
Jeff
The light goes out as soon as I turn the key it doesn't flash. I don't know if there is another switch or relay after the ingition switch and before the starter.
Ed
does anyone know about a starter engage module. They say its behind the IP on the right side of the radio. What do they mean by IP
Thanks Kev feeling a little dumb now. Well I found the problem It was the ignition switch. The new I got from the supplier was also bad. Starting like it should. Thanks again for the come back.
Ed
