A question on 93-97 Camaro differentials -
Are these C-clip axles in these rear ends? The reason I ask is because I'm swapping rear disc brakes from one of these rears onto my 69 Camaro. The C-clip type axles have a bit of in/out play to them. I was just wondering if that play would tend to push the piston into the caliper causing a soft pedal. I realize the calipers "float" on the slide pins - just wondering if they are engineered to work with this type of axle. Thanks!
