I just recently purchased a 96 Camaro and occasionally when I brake the low trac light will come on a few times only during braking then eventualy it will disengage the abs system...Any suggestions? I'd like to know alittle about it before I go to the dealer for the ream job...ha ha...Thanks
i think u need to takr it to the dealer b/c it sounds like it has a major short some were wich soon u might not have brakes
I have a 94 camaro and it did that when I first got mine two years ago. The low trac light came on and eventually the ABS light came on also. All I did was replace the break pads. Then it stopped. It started back a few weeks ago and sure enough, the break pads needed replaced. Might be something to look at.
Posted from the original: It seems to only do it when I keep the 35 PSI recommended tire pressure...other than that I don't have any other problems with the system.
