I have a 99 with the series II V-6. This things runs great, good power etc. But at idle it makes the strangest sound. Sounds "like" an alternator grind from deep in the motor along with a slight knock. Goes away with engine under load, but not right off idle it needs to be loaded. The motor is original with 111*** on it. Oil pressure good, and steady. We have put nearly 10,000 miles on it after buying it and no change to sound.
disclaimer: Adult driven, no burn outs or WOT pulls :cool: yeah right
I have heard this noise from other cars in parking lots etc. Frequently from mini vans of the same era.
Is this common to 3.8s ?
Are there balance rods in these engines? I have looked around and am not finding any info. Aren't these gear driven cams?
Run it with the serpentine belt off and see if the growl goes away.These guys eat water pump bearings up.
That'll be an easy check thanks!
tensioners were bad to make that noise too!!
