I only recently detected minor leaks in the inside of my car at each upper corner of the front windshield, running down the pillar. The car was under an extended period of constant rain for almost a full day. Naturally the water collected in the low spots of the floor on both sides. I managed to sponge out access water under the carpet, but do not have a wet-vac which probably should be used.
I did place a container of Damp-Rid for a full day to remove all air-borne dampnest.
I also looked at the rubber moldings around both the T-top and each door (rubber) molding which appear to be in good shape. If anyone knows of a remedy to eliminate minor leaking please let me know.
Regards,
tblazer:yes:
