These may come in handly:
---1999 Pontiac Firebird Security Information---
Constant 12V+ - Red - Ignition Switch Harness
Starter - Yellow - Ignition Switch Harness
Ignition - Pink - Ignition Switch Harness
Ignition 2 - Brown - Ignition Switch Harness
Accessory - Orange - Ignition Switch Harness (Heat/AC)
Tach - White V6 - Red/Black (-) - V8 Coil or White PCM Firewall
Neutral Safety Wire - Orange/Black (-) - Switch Base of Gear Shift
Brake Switch - Light Blue or White - Brake Switch
Trunk Release - Black/White (+) - Switch or Brown at Blue -Connector on BCM
Trunk Pin - Orange/Black (-) - BCM Blue Connector Passenger's Kick Panel
Parking Lights - Brown (+) - Head Light Switch or Blue Connector BCM
Head Lamp - Yellow (+) - Light Switch
Door Trigger - Gray/Black (-)DR - Black/White Passenger's Blue Connector at BCM
Door Lock - Red/Black (-) - BCM Passenger's Kick
Door Unlock - Orange/Black (-)
Horn Wire - Black (-) - Steering Column or BCM
Windows Up - LF=Blue, RF=Blue
Windows Down - LF=Brown, RF=Tan
---1993-94 Chevrolet Camaro Security Information---
Constant 12V+ > Red > Ignition Switch Harness
Starter > Yellow > Ignition Switch Harness
Ignition > Pink > Ignition Switch Harness
Accessory > Orange > Ignition Switch Harness
Tach > White V6 > Or White/Black (-) V8 At Coil or Distributor
Brake Switch > Yellow > Brake Switch
Trunk Release > Black (+) > Switch or Driver's Kick Panel
Trunk Pin > Gray (-) > Behind left Rear Speaker
Parking Lights > Brown (+) > Driver's Kick Panel
Head Lamp > Yellow > Light Switch
Hood Pin > n/a
Door Trigger > Gray/Black (-) > Driver's Kick Panel
Door Lock > Red/Black > Driver's Kick Panel Reverse Polarity
Door Unlock > Orange/Black > Passenger's Switch is Master Switch
Horn Wire > Black (-) > Steering Column
Windows Up > L=Dark Blue, R=Light Blue
Windows Down > L=Brown, R=Tan
