Does anyone have, or can they take measurements of their upper and lower A-arms at the bushing flanges?
This would help a lot of people determine if their arms have been bent. I've got an arm (upper) that I know for sure is bent at one of the bushing holes and I can repair it but I don't know how far back to move it.
Can someone with known good lower arms measure the inside dimension between the bushing flanges and then the outside edges? And also the outside bushing flange edge to edge on the uppers? As close as you can approximate within a sixteenth.... nothing scientific. I'm sure they're all different
Then we'd at least have a little better idea how far off and how much to move them back. I know there could be a dozen different measurements from a dozen different people but at least we could "guess-timate" a good average of the dimensions and have a pretty close final figure.
I measured mine but didn't compare them to the cooresponding mounting points on the subframe yet. I want to try to adjust the bushing points to mate my frame as perfectly as possible. I know, LOTS of work!
Thanks in advance anyone.... I'll owe you a cold one.
EDIT: I realize it's more important that the bushings be straight in relation to their pivot points. But knowing an approximate proper length dimension for the centerline between them will help.
[ 07-11-2003, 07:05 PM: Message edited by: HwyStarJoe ]
I just saw this post and will measure a spare set I have. However, I know when I pressed in the bushings, and made a L spacer to avoid bending them, that both sides weren't equal. Close but not the same. I'll post them anyhow. They didn't look bent and, who knows, given late 60's precision.
Joe, I got these off of 4 uppers and 3 lowers.
UCA
The originals ( still with bushings ) measure 9 11/16 and 9 12/16 between the flanges. The other ones that I have put bushings in measure 9 10/16 and 9 11/16.
LCA
The one original measures 1 7/16 between the 'ears' on both with an inside distance of 9.5. The other two, that I have put bushings in, also measure 9.5 inside and the ears are 1.5 on one and 1 7/16 on the other.
