1 - 8 of 8 Posts
I am done with my wiring!! Whew hew!! I think anyways.. I am just about to put the fuses into the fuse box but this is where I am lost.. which fuses go into what? I know this may sound like a dumb question, I went through the direction and couldn't find a diagram.. anyone had this problem? I have instructions all over the place so maybe I have overlooked a set.. please let me know if I may have overlooked something or if you can tell me how to install these fuses..
Chip....it should tell you on the fuse box which amperage rated fuse to use, ie 5A, 10A, 20A, etc. Don't put one in a slot that is higher than the rating on the box. An overload and possible fire can result.
They aren't labeled on the box.
Chip, the fuse box map is on one of the pages for the dash harness. For my 69, the fuse box diagram is on Sheet 1 of the dash kit instructions. It's off on the left of the page, and just has the slots labeled with fuse amperage values. It's not real obvious, so it's easy to overlook.
1 - 8 of 8 Posts
