1 - 2 of 2 Posts
For those of you that have replaced your AC wiring harness, what is the easiest way to remove the wires from the fan. I can't seem to get my hand under the fender and back far enough to find where they connect to the fan motor. Any help is appreciated. Thanks Dave
If you are not concerned with originality, previous owner of my car cut a rectangle hole in the inner fender behind the Pass. side front tire to access the fan wires that tuck down there. It has come in very handy to say the least. Just an idea if you dont mind having a patch panel of steel screwed over the hole to cover it up and keep out dirt etc.
You can see the 2 connections in the pics, the one has a black weather seal around it that locks around the base of the terminal, the other wire is a simple ground with push on male/female connection.
1 - 2 of 2 Posts
