Hey guys, my acc pump is leaking from the diaphragm. I have a 69 Z 28 4053 Holley on my 69 Z 302. Do I need the 30 or 50 cc pump diaphragm? They also list if they put alcohol in the gas where you live. I am in Southern California and haven't a clue what they put in the gas here.
thanks for the assist
alan
Also, on the fuel pipe that goes to each bowl from the fuel block, are there supposed to be copper washers for any of the 5 connections or is it just the flare to the block? Those things have always been hard to seal.
It's just flare , and it's probably the accelerator pump housing is warped from heat, usually it's not the diaphram. Face the hsg off on a piece of glass with some 180 paper.
Thannks Mike. I pulled the carb last night. The diaprhagm was really stiff and crappy. But I will check the housing for flatness. Good point!!!
Per Holley, Tom was correct, a 30 cc diaprhagm and all Holley's rubber parts are now ethanol safe.
Thanks Guys!!!!:beers:
